Focus Shots
Standard Equipment
●M4P Mission Drone Kit Set x 1
●Transmitter x 1
●M8 Motor Set x 4 set (Max. Tensile Force: 12kg/set)
●AP6 Flight Control x 1
●G3P 4K Three-axis Gimbal x 1
●Millimeter Wave Radar x 1
●Auto Retractable Landing Skid x 1 set
●Enhanced Control Hook x 1(Max. Tensile Force: 20kg)
●Headlight x 1
●6S 16000mAh Intelligent Battery x 2
●Balance Charger x 1
ALIGN M4P TOP Product Specification
Airframe: 1095mm
Height: 405mm
Foldable Rotor: 23 Inch
Main Rotor Diameter: 585mm
Power System: M8 Motor
Empty Weight: 6.9kg
Load Capacity:10Kg
Flying weight: 11Kg (including battery 12S 16000mAh)
Flying weight: 12.4Kg (including battery 12S 22000mAh)
Max. Flying Weight: 22.4kg
Flight Time without payload:
  33min.(with battery 12S 16000mAh, 11kg without load)
  41min.(with battery 12S 22000mAh, 12.4kg without load)
Positioning Precision: within 1 meter
Max. Video Transmission Distance:
   <4000 meter(w/o interference and/or obstacle)
Max. Radio Control Distance:
   6000~10000 meter (w/o interference and/or obstacle)
ALIGN M4P TOP Specification
M8 Motor Power Set Specification
●Max. Tensile Force : 12kg/Set(48V)
●Recommended Battery:12S (LiPo)
●External Diameter:70mm
●KV Value : 180KV
●Weight:720g
●Working Environment Temperature : -20~50℃
Flight Safety
