Top » Home Shop » RC World » Agricultural Drone » Agricultural Drone Batteries » HBP16003
US$ 47.99
Li-Po High Voltage Battery 6S 16000mAh
HBP16003
US$ 243
Appearance:
Appearance:
●Suitable for ALIGN Agricultural Drone/M4P Mission Drone/E1 V2 Mission Helicopter use.
●Max Continuous Discharge: 15C.
NOTE:
●Output:26.1V/16000mAh 417.6Wh(6S1P)
●Support 1C charging.
●Dimension:185x74x58mm
●Weight:1740g
●Max Continuous Discharge:15C
●Amass XT90S-F Fire-Proof Connector
This Product was added to our catalog on Tuesday, 23. June 2026.
