Top » Home Shop » RC World » Helicopter » Servo » Digital Servo » HSD65501
€ 10
DS655 Digital Servo
HSD65501
DS655 Digital Servo
€ 68.99
●Ultra-speed servo for instant tail control reaction. (0.05sec/60 deg).
●Ultra Performance Coreless Motor with fast reaction and low current.
●Hardened high strength superalloy gears that increase the lifetime.
●Powerful and precise servo, suitable for T-Rex 600/700/800 rudder use.
●Stall torque:4.5kg.cm(4.8V)
                   5.5kg.cm(6.0V)
●Motion speed:0.06sec/60°(4.8V)
                     0.05sec/60°(6.0V)
●Rating voltage:DC 4.8-6V
●Dimension:40.1 x 20.1 x 37.3mm
●Weight:56g
●1520μs standard band
●Servo rudder piece x 2
●Set screw x 1
●Rubber damper x 4
●Brass grommet x 4
●Socket button head tapping screw × 4(T2.6x12mm)
This Product was added to our catalog on Thursday, 09. August 2012.
