Top » Home Shop » RC World » Helicopter » Helicopter Motor » Brushless Motor » HML73M01
€ 147
730MX Brushless Motor(850KV/4230)
HML73M01
€ 137.99
HML73M01
Drawing:
Specification Drawing:
Wiring Schematic Drawing:
Instructions: Specification:
Brand new 730MX motor is especially designed for power upgraded T-REX 550E, normally found in 700 class high spec helicopter, that enthusiasts can clearly feel the dramatic increase in power and torque, while taking advantage of its higher efficiency, lower current and temperature benefits.
●The 730MX(850KV) motor armature had a special balance adjust to improve the serious shaking problem that other tiny motors have.
●Suitable for T-REX 550X/550E helicopters,Must with 550E PRO Motor Mount(H55B002XXW)、550E PRO Carbon Fiber Main Frame-2.0mm(H55B003XXW)、Motor Pinion Helical Gear 16T(H55G003XXW)
●Manual Download:
●Input voltage: 6S
●Max continuous current: 115A/195A(5sec)
●Max output power: 2550W/4330W(5sec)
●KV value: 850KV
●Stator Dimension:4230
●Stator Arms: 12
●Magnet Poles: 8
●Dimension: 6x52x89.1mm
●Weight: 380g
●Socket screw(M4X10) x 2
●Washer(Φ4XΦ10X1) x 2
●4mm gilt terminal x 3
This Product was added to our catalog on Saturday, 14. September 2013.
