Top » Home Shop » RC World » Helicopter » Heli Parts » 150 Parts » HBP03001
 RC World
 -   Helicopter
    Helicopters
    Heli Parts
      100 Parts
      150 Parts
      T15 Parts
      250 Parts
      300X Parts
      450 Parts
      450L Parts
      TB40 Parts
      470L Parts
      500L Parts
      500X Parts
      550E Parts
      550L Parts
      550X Parts
      TB60 Parts
      600L Parts
      600 Nitro Parts
      600XN Parts
      650 Parts
      700E Parts
      TB70 Parts
      700X Parts
      TN70 Nitro Parts
      700 Nitro Parts
      700XN Parts
      760 Parts
      800E Part
      E1 900 Parts
      Three Blade
    Helicopter Motor
    Helicopter Main Blade
    Helicopter Tail Blade
    Helicopter Fuselage
    Heli Canopy
    Helicopter Electric Equipment
    Brushless ESC
    Servo
    Charger/Batteries
    Bearing
    Helicopter Screw Parts
 -   Mission Helicopter
 -   Agricultural Helicopter
 -   Agricultural Drone
 -   Lawn Mower
 -   DJI植保無人機
 -   FPV
 -   Control Radio
 -   Flying Simulator
 -   RC Articles
 Vacuum Cleaner
 Milling Machine Equipment
€ 147
Li-Po Battery 2S 300mAh
HBP03001
€ 16.99
●Use for T-REX 150.
●This Li-poly battery is using series/balancing design, features high efficient and high discharge.
●Max Continuous Discharge: 30C.
NOTE:
●Output:7.4V 300mAh 2.22Wh(2S1P)
●Support 5C charging.
●Dimension:54x21.5x12mm
●Weight:18g
This Product was added to our catalog on Thursday, 07. August 2014.
