Specification
●Screen: 7" TFT LCD screen/long life, LED backlight
●Resolution: 800x480 dot pitch
●Brightness: 450cd/m2
●Contrast: 500:1
●View Angle: 140/120 degree(H/V)
●Antenna Connector: RP-SMA
●Dimension: 176x112x24mm (Height of light shield:102mm)
●Battery: Built-in 4000mAh Li-Po battery
●DC: 12V/1A
●Power Consumption: 600mA@12V(maximum)
●Working: -10°C ~ +65°C
Features
●Utilizes 7" TFT LCD screen, LED backlight.
●With automatic searching, simple and easy to operate.
●Built in 32 channel dual receiver system featuring efficient reception and good stability can receive two different channel separately.
●Built in high capacity 4000mAh Li-Polymer Battery, featuring durability over 3 hours with full charge.
●DC 12V input/output, with power cable which supports external 3S battery charging. When run out of built in battery, it can connect to external power supply.
●Multiple connectivity options can connect to transmitter or bracket easily.
●Foldable sunshield featuring lightweight, easy to carry and not occupy space, even in bright light still can see clearly.
●Support AV IN/AV OUT.
Content
●Mainframe x 1
●Transmitter Bracket x 1
●Tripod Connector x 1
●AV Cable x 1
●Power Cable x 1
Optional
●T10 Transmitter
●T10 Transmitter Bracket
●Camera Bracket
●Mounting Screw
Manual
