Top » Home Shop » RC World » Helicopter » Charger/Batteries » Batteries » HBP33004
€ 16
Li-Po Battery 3S 3300mAh
HBP33004
€ 45.99
Appearance:
●Suitable for E1 PLUS Agricultural Helicopter PCU power supply.
●Max Continuous Discharge: 50C.
NOTE:
●Output:11.1V 3300mAh 36.6Wh (3S1P)
●Support 5C charging.
●Dimension:142x44x22.5mm
●Weight:250g(Not including connectors)
●Max Continuous Discharge:50C
●Amass XT30-F Connector
This Product was added to our catalog on Friday, 19. July 2019.
