Top » Home Shop » RC World » Agricultural Helicopter » E1 Agricultural Helicopter Electric Equipment » HEG00012A
€ 10
3S High-pressure Pump
HEG00012A
€ 62
Appearance:
●Suitable for ALIGN Agricultural Drone。
●The high-pressure pump is specially designed for agricultural spraying. The internal motor spindle adopts a 3-bearing fixed design, which greatly improves the stability of the pump during operation and effectively extends the service life.
●Enlarged metal motor mount design, structural strength is improved, the spraying pressure of the pump is more constant, and the heat dissipation function of the pump is provided when the pump is running, so that the pump water output can be increased up to 5L/min.
●Pump input voltage: DC12V
●Pump current consumption: 5A
●Pump flow: 5L/min
●Max. pump pressure: 0.5MPa
Content:
●3S High-pressure Pump x 1
This Product was added to our catalog on Tuesday, 26. January 2021.
