Top » Home Shop » RC World » Helicopter » Heli Parts » E1 900 Parts » HE1B053XXW
 RC World
 -   Helicopter
    Helicopters
    Heli Parts
      100 Parts
      150 Parts
      T15 Parts
      250 Parts
      300X Parts
      450 Parts
      450L Parts
      TB40 Parts
      470L Parts
      500L Parts
      500X Parts
      550E Parts
      550L Parts
      550X Parts
      TB60 Parts
      600L Parts
      600 Nitro Parts
      600XN Parts
      650 Parts
      700E Parts
      TB70 Parts
      700X Parts
      TN70 Nitro Parts
      700 Nitro Parts
      700XN Parts
      760 Parts
      800E Part
      E1 900 Parts
      Three Blade
    Helicopter Motor
    Helicopter Main Blade
    Helicopter Tail Blade
    Helicopter Fuselage
    Heli Canopy
    Helicopter Electric Equipment
    Brushless ESC
    Servo
    Bearing
    Helicopter Screw Parts
 -   Mission Helicopter
 -   Agricultural Helicopter
 -   Agricultural Drone
 -   Lawn Mower
 -   DJI植保無人機
 -   FPV
 -   Control Radio/Flying Simulator
 -   Charger/Batteries
 -   RC Articles
 Vacuum Cleaner
 Milling Machine Equipment
€ 20
E1 Fire Extinguishing Ball Conversion Set
HE1B053XXW
€ 1,100
Instruction:
Instruction:
Appearance:
Size:
●Suitable for ALIGN E1 900 / E1 PLUS.
●E1’s excellent load capacity and high stability flight, with ALIGN original hook, can hang a total of six fire extinguishing balls with a total weight of 7.2 kg, through the high-definition 720 DV video return, remote control by the transmitter, Even at an altitude of tens of meters above the ground, it is still stably and accurately dropped to the target place, realizing the perfect airdrop operation of the fire extinguishing ball. E1 has a working radius of 1.5KM and a flying height limit of 300M.
●The fire extinguishing ball can be placed in sequence through the transmitter button, or controlled through the ground station APP. It can be placed all at once or selected by number.
●Use for chemical factory firefighting, forest firefighting, emergency firefighting of high-altitude, military applications, maritime rescue, and the delivery of materials in disaster areas…etc.
AUTO FIRE OFF fire extinguishing ball function description:
●Optional parts.
●Lightweight and beautiful, easy to use and light weight with only 1.2 kg.
●E1 is equipped with fire extinguishing ball to be put into the forest fire, as long as it is in contact with the flame for 3 to 5 seconds, the fire extinguishing ball can be exploded. Class A, B, C fire extinguishing powder can quickly disperse the fire source, or it can be placed around the fire scene to set up the fire line to achieve the preventive effect.
●After being heated, the fire-extinguishing dry powder in the ball is evenly exploded and dispersed to achieve the fire-extinguishing effect. After use, the dry powder can be converted into fertilizer for use, which is environmentally friendly and pollution-free.
E1 fire extinguishing ball conversion set
● Input voltage: 8.4V
● Number of mounts: 6
● Max. weight of single mount: 2.5kg
● Max. weight of all mounts: 15kg
● Launch control: Transmitter & Ground station
Servo hook set specification
●Input voltage: 5V~8.4V
●Operating temperature: -10°C~50°C
●Expansion time: 8.4V/5 seconds
Content:
● Enhanced Hook x 6
● Controller x 1
● E1 Hook Mount(378x78.5x2mm) x 2
● Millimeter Wave Radar Mount(114x86x1.6mm) x 1
● E1 Radar Bolt(M3x40mm) x 4
● E1 Skid Sleeve x 4
● Socket screw(M4x8mm) x 4
● Socket screw(M3x6mm) x 8
This Product was added to our catalog on Friday, 29. January 2021.
