Focus Shots
Standard Equipment
●ALIGN M6T22 V2 Kits Set x 1 set
●22L Chemical Container x 1
●M6 Motor Power System x 6
(Max. Tensile Force : 15.5 KG/Set)
●Transmitter set x 1
●Remote Control Super Bright Headlight x 1
●Millimeter Wave Radar x 1
●Portable 3K Carbon Fiber Battery Mount x 1
Shipping Instructions
Pre-assembled and well-tested in factory.
Packing Dimension
ALIGN M6T22 V2 Product Specification
Airframe: 1620mm
Height: 628mm
Foldable Rotor: 3090(350mm)
Main Rotor Diameter: 778mm
Power System: M6 Motor (Max. Tensile Force 15.5kg/set)
Chemical Container: 22L
Limited Payload: 20L
Empty weight: 18.2kg
Maximum flight weight: 45kg
Max. Working Speed: 20km/H.
Flight Time Without Payload:
Approx. 29 mins. (w/ 22000mAh battery x 2)
Spray Operation Flight Time:
Approx. 8~10 mins. (w/ 22000mAh battery x 2)
Max. Wind-resistance: force 8 wind
Self-provided Equipment
1200W Balance Charger (AC 110V~220V) x 2 set
●Main Power Battery 6S Li-Po 16000~22000mAh x 4 pcs (= 2 set) and more
ALIGN Flying Simulator for flying practice
ALIGN M6T22 V2 Specification
M6 Motor Power Set Specification
●Recommended Battery:12S (LiPo)
●Sustained Ceiling Current:80A(2sec)
●Max. Tensile Force : 15.5kg/Set (46V)
●Weight:1040g
● Working Environment Temperature : -20~65℃
● Protection Rating : IPX7
●Emission Frequency:24Ghz
●Emission Power ( EIRP ):20 dBm
●Measurement Accuracy:5cm
●Update Rate:94Hz
●Working Temperature:-25℃~85℃
●Dimension:80.7x80.4x15mm(HxWxD)
●Weight:82.8g
ALIGN M6T22 Drone Wind Tunnel Test
Flight Safety
