Top » Home Shop » RC World » Helicopter » Charger/Batteries » Batteries » HBP04001
€ 0.8
Li-Po Battery 2S 400mAh
HBP04001
€ 11.99
●Suitable for T15.
●This Li-poly battery is using series/balancing design, features high efficient and high discharge.
●Max Continuous Discharge: 50C.
NOTE:
●Output:7.4V 400mAh 2.96Wh(2S1P)
●Support 5C charging.
●Dimension:46.4x20.6x13.82mm
●Weight:23.8g
Content:
●Li-Po Battery 2S 400mAh x 1
Note: Urethane foam is attached on some battery for height adjustment
This Product was added to our catalog on Wednesday, 31. August 2022.
