Top » Home Shop » RC World » Helicopter » Charger/Batteries » Batteries » HBP22009
€ 22
Li-Po Battery 6S 2200mAh
HBP22009
€ 51.99
Appearance:
Protecting cover diagram:
●Suitable for T-REX 470 series.
●This Li-poly battery features high efficient and high discharge, use a inspection machine to match packs, suitable for other professional model airplanes, cars, and guns.
●Max Continuous Discharge: 45C.
NOTE:
●Output: 22.2V 2200mAh 48.8Wh(6S1P)
●Support 5C charging.
●Dimension: 107x34x50mm
●Weight: Approx. 350g
●Amass XT60-F Connector
This Product was added to our catalog on Friday, 19. May 2023.
