Top » Home Shop » RC World » Aerial Photography / Mission Drone » Charger/Battery » HEC00009
€ 147
RCC-2P Dual Channel Intelligent Charger
HEC00009
€ 193
Instructions: Specification:
It supports dual-channel simultaneous output. When one channel is charging, the second channel can be set for charging and discharging; data such as battery type, charging current, and cut-off voltage can be adjusted with high precision according to user needs.
Provided maximum power of 400W charge, significantly reducing charging time. With 4 function buttons for easy operation and LCD display, the battery charging status can be monitored in the charging process at any time.
●Support two sets of battery with 1~6 cells (LiPo / LiHV).
●Multiple Protection Functions: Overload Protection, Overcurrent Protection
NOTE:
3.Before placing your order, please make sure to confirm local voltage for buying correct input voltage charger to prevent any unexpected danger and fire resulting from wrong voltage input.
4.Keep the charger and battery away from flammable items.
5.Never leave the charger unattended, in case of causing an accident.
6.The battery should be charged under 5-40 degree Celsius environment.
7.Keep the charger away from dust, moist, rain, heat, direct sunshine and vibration.
8.Before you power off the charger, please “stop” the charger first, unplug the battery, then unplug the power cord of the charger.
●Input Voltage :AC 100~240V / DC 9.0~32.0V
●Charging Ports :2 ports
●Charging Power :AC 200W / DC 400W
●Support Battery Type :LiPo Battery/ LiHV Battery (1 ~ 6S)
●Charing Current :0.1~10A
●Discharging Power :6W
●Balanced Current :1000mA/Cell
●Output Voltage :DC 26.1V(MAX)
●Protection Functions :Overload Protection, Overcurrent Protection
●Display :LCD Intelligent Display
●Size :100x99x64mm
●Weight :450g
Content:
●RCC-2P Dual Channel Intelligent Charger x 1
●Balance Connector x 2
●Charging cable x 2
●power cord x 1
This Product was added to our catalog on Wednesday, 20. December 2023.
