Focus Shots
Standard Equipment
●ALIGN E1 Kits Set x 1 set
●900mm Carbon Fiber Blades x 1 set
●120mm Fiber Tail Blades x 1 set
●A13P Transmitter set(include A6B Receiver) x 1
●5.5L Chemical Container x 2
●Main Power - 950MX Brushless Motor x 1
ALIGN E1 PLUS Product Specification
●Body Length:2192mm
●Body Height:575mm
●Body Width:458mm
●Main Rotor Length:900mm
●Main Rotor Diameter:1982mm
●Tail Rotor Diameter:313mm
●Empty Weight:Approx. 9.78kg
●Max Takeoff Weight:Approx. 25.5kg (w/ 11L Container)
●Brushless Motor:950MX
●Max Output Power:5100W/11000W(2sec)
●Chemical Container:11L
●Flight Time:(Payload: 10L):Approx. 4min.
Self-provided Equipment
●UP600+ Balance Charger (AC 110V or AC 220V) x 2 set
●Main Power Battery 6S Li-Po 10000~16000mAh x 8 pcs (= 4 set) and more
●PCU Battery 3S 2200~3300mAh x 2 set and more
● ALIGN Flying Simulator for flying practice.
●8" Tablet
  • * AP2 Flight Control System supports Android 8.0 and 9.0.
  • * Considering the best working efficiency, the specifications of the tablet are recommended as follows: 8” Tablet, 6 Core CPU, 3GB RAM, more than 32GB ROM storage space and support 5G Wi-Fi.
  • * The max. dimension of screen bracket is 240 x 169mm.
●Tablet Suggestions:
  Samsung Galaxy Tab A /Model Type:SM-T385
  Samsung Galaxy Tab A 8.0 /Model Type:T295 (LTE)
  Samsung Galaxy P200
  Samsung Galaxy Tab A 10.1 /Model Type:SM-T510
  Mi Band 4
  ASUS ZenPad 3 8.0 /Model Type:Z581KL
ALIGN E1 PLUS Specification
A13 GST Transmitter
●Channel: 14 channels
●Model Type: Helicopter / Multicopter
●RF Range: 2.4055~2.475GHz
●RF: < 20dBm
●System Mode: 2.4G system AFHDS
●Power: Built-in 2S 7.4V 8700mAh Li-Polymer Battery
●Working Hours: Around 6.5 hrs after fully charged
●Display: 128x64mm
●Transmit Distance: In the air without interference <1000M
●Weight: 650g
●Dimension: 167x180x103mm
●Certificate: FCC, NCC(CCAK19LP0390T9)
A6B Receiver
●RX Sensitivity: -105dBm
●RF Range: 2.4055 ~ 2.475 GHz
●Power: 4.0 ~ 8.4V
●Weight: 14g
●Dimension: 46.7x25.5x13.6mm
●Certificate: FCC, NCC(CCAK18LP1930T2)
●Input Voltage:12S
●Max Continuous Current:120A/250A(2sec)
●Max Output Power:5300W/11000W(2sec)
●Stator Arms:12
●Magnet Poles:10
●Dimension:6x56.7x117.5mm
●Weight:663g
Flight Safety
