Focus Shots
Specification
●Screen: 5" TFT LCD screen
●Resolution: 800x480 dot pitch
●Brightness: 450cd/m2
●Aspect Ratio: 16:9
●TV System: PAL / NTSC
●Antenna Connector: RP-SMA External thread, Inner needle
●Dimension: 128.5 x 83 x 11.5(mm)
●Weight: 165g
●Charging current: DC5.0V / 1A
●Battery: Built-in 1S 3.7V 2500mAh Li-Po battery featuring durability 2-2.5 hours with full charge
●Working: -10°C ~ +65°C
Features
●5 Frequency and 40 Channel.
●Including most 5.8GHZ wireless devices.
●Small and lightweight design, easy to carry.
●Built-in high-capacity polymer battery for outdoor use.
●Press one button for automatic searching switch which is easy to operate.
●Supports screen recording function (micro SD up to 32G).
●OSD information display allow to ,working condition.
●Micro USB allows for power input.
●Supports multi laguage.
●Supports firmware update.
Content
●5" LCD Monitor x 1
●5" LCD Monitor Bracket x 1
●5" LCD Monitor Bracket Mounting Block x 1
●5" LCD Monitor Housing x 1
●5" LCD Monitor Mounting Screw x 1
●T10 Transmitter Round Head Slotted Screw(M4x14mm) x 1
●T10 Transmitter M4 Nut(M4x5.5mm) x 1
●Circular Polarized Antenna x 1
●Tripod Connector x 1
●Micro USB Wire x 1
●AV Signal Wire x 1
Optional
●T10 Transmitter
Manual
