Top » Home Shop » RC World » Helicopter » Servo » Digital Servo » HSD45501
€ 147
DS455M Digital Servo
HSD45501
€ 39.99
●Faster speed with high torque performance, allowing helicopter to perform with faster and higher precision.
●High rigidity, shock resistant metal gears with high strength composite alloy gears with durable structure characteristics.
●Powerful and precise servo, suitable for T-Rex 250/450 rudder use.
●Supports 8.4v high voltage input to provide optimal speed and torque performance of the servo.
●Stall torque: 2.2kg.cm(6.0V)
                    2.9kg.cm(8.4V)
●Motion speed: 0.05sec/60°(6.0V)
                       0.04sec/60°(8.4V)
●Rating voltage: DC 6.0-8.4V
●Dimension: 23 x 12 x 31.3mm
●Weight: 20g
●DS450 Digital Servo x 1
●Socket Button Head Self Tapping Screw x 2
●Socket Screw x 1
●Servo Arm x 2
This Product was added to our catalog on Friday, 17. June 2016.
