Top » Home Shop » RC World » Helicopter » Charger/Batteries » Recharger » HEC30001
€ 49
RCC-300 Battery Charger
HEC30001
€ 123.99
Instructions: Specification:
Provides 300 Watts - 25 Amps charge/discharge service significantly shorten the charging time. For ease of uses a convenient user-friendly touch screen interface which displays the charging status.
●Touch Screen
●Program Data Save / Load
●PC Interface
●End Voltage Controlled
●Storage Charge
●Maximum Safety
●Cooling System
●32Bit MCU Processor
●Discharge
●Delta Peak Sensitive
●Nixx Battery Cycles
●Battery Meter
●Safety Timer
●Temperature Sensor
NOTE:
●DC input voltage: 11-32V
●Charge power: 300W
●Discharge power: 30W
●Charge current: 0.1-25A
●Regenerative discharge power: Max.300W
●LiPo/Li-lon/ Life battery cell count: 1-6S
●NiMH/NiCd battery cell count: 1-16 cells
●Pb battery voltage: 2-20V
●Dimension: 102x120x46mm
●Weight: Approx. 450g
●RCC-300 Balance Charger x 1
●Stylus Pen x 1
●XH Balance Board x 1
●TX60 Male Wire Set x 1
●TX60 Female Wire Set x 1
●Please provide power supply for yourself, specification:DC output 11~32V
This Product was added to our catalog on Saturday, 10. September 2016.
