Top » Home Shop » RC World » FPV » MR25 Charger/Battery » HBP22012
€ 10
Li-Po Battery 3S 2200mAh
HBP22012
€ 23
Appearance:
MR25 Power Tip:
Align Motor Battery
Propeller
5040
[MP05032]
5045
[MP05031]
6040
[MP06031]
RCM-BL1806
[HML1806M01]
[HML1806M02]
3 Cell
[HBP13004]
[HBP22012]
V V V
4 Cell
V V Prohibited
RCM-BL2205
[M425022XXW]
[HML2205M01]
[HML2205M02]
3 Cell
[HBP13001]
[HBP18001]
V V V
4 Cell
V V Prohibited
●Suitable for MR25 series.
●This Li-poly battery features high efficient and high discharge, use a inspection machine to match packs, suitable for other professional model airplanes, cars, and guns.
●Max Continuous Discharge: 30C(39A).
NOTE:
●Output: 11.1V 2200mAh 24.4Wh(3S1P)
●Support 5C charging.
●Dimension: 110x35x20mm
●Weight: 151g
●Amass XT30U-F Connector
●Included Hook and Loop Tape- Loop side (fuzzy) x 1
This Product was added to our catalog on Tuesday, 20. January 2026.
