Top » Home Shop » RC World » Helicopter » Heli Parts » Three Blade » 550E Three-Blade » H55H004XXW
 RC World
 -   Helicopter
    Helicopters
    Heli Parts
      100 Parts
      150 Parts
      T15 Parts
      250 Parts
      300X Parts
      450 Parts
      450L Parts
      TB40 Parts
      470L Parts
      500L Parts
      500X Parts
      550E Parts
      550L Parts
      550X Parts
      TB60 Parts
      600L Parts
      600 Nitro Parts
      600XN Parts
      650 Parts
      700E Parts
      TB70 Parts
      700X Parts
      TN70 Nitro Parts
      700 Nitro Parts
      700XN Parts
      760 Parts
      800E Part
      E1 900 Parts
      Three Blade
        700E Three-Blade
        550E Three-Blade
    Helicopter Motor
    Helicopter Main Blade
    Helicopter Tail Blade
    Helicopter Fuselage
    Heli Canopy
    Helicopter Electric Equipment
    Brushless ESC
    Servo
    Charger/Batteries
    Bearing
    Helicopter Screw Parts
 -   Mission Helicopter
 -   Agricultural Helicopter
 -   Agricultural Drone
 -   Lawn Mower
 -   DJI植保無人機
 -   Racing Drone
 -   Control Radio
 -   Flying Simulator
 -   RC Articles
 Vacuum Cleaner
 Milling Machine Equipment
US$ 104
550E Three-Blade Rotor Head
H55H004XXW
US$ 218.99
●Suitable for T-REX 550/600
●For T-REX 550E and T-REX 600, must use with 600DFC Main Shaft Set(H60243A).
●The new 550E Three-Blade Rotor Head is specially made from 3-D rotation surface process, as well as aerospace grade aluminum alloy, strongly enhance structural toughness and precision. Also painted with high texture and bright red satin plating color highlight the extraordinary craftsmanship and beauty all in one. The new three-blade head provide superior flight stability with low CG design allow to reduce flying resistance but bring more rigidity and fast response on the other hand. Pilots can easily control between active and static condition, and enjoy the pleasure from the flight.
Optional Equipment:
●550E Three Tail Blade Set(H55T005XXW)
●520 Carbon Fiber Blades / 3(HD520D)
●90 Carbon Fiber Tail Blades / 3(HQ0900D)
●Three-Blade Rotor Housing x 1
●Metal Main Rotor Holder x 3
●Three-Blade Shaft Set x 3
●Head Damper (Φ8xΦ12.9x6.5mm) x 3
●Elevator ball link (Φ5xΦ6x19mm) x 6
●550E Three-Blade Shaft screw x 3
●Linkage rod A x 3
●Spacer (Φ8xΦ11x1.3mm) x 3
●Spindle bearing spacer (Φ10xΦ13.8x0.4mm) x 6
●Thrust Bearing F8-14M (Φ8xΦ14x4.5mm) x 3
●MR148ZZ Bearing (Φ8xΦ14x4mm) x 6
●Washer (Φ5xΦ12x1mm) x 3
●Socket Collar Screw (M3x6mm) x 6
●Socket Screw (M3x10mm) x 2
●Socket Button Head Screw (M2.5x8mm) x 2
●Socket Collar Screw (M3x19mm) x 2
●Socket Collar Screw (M4x25mm) x 3
●Socket Screw (M5x10mm) x 3
●M3 Nut x 2
●M4 Nut x 3
●Main Blade Grip Arm x 3
●Φ5 Linkage Ball B (M3x4) x 3
●Elevator Arm Set x 2
●Linkage Rod Set x 1
●Washer (Φ3xΦ4.8x0.3mm) x 2
●Linkage rod holder x 6
●550E Three-Blade Rotor Main Shaft x 1
●Main shaft spacer 0.3mm x 1
●Main shaft spacer 0.5mm x 1
●CCPM Metal Swashplate x 1
●Linkage Ball B (M3x4) x 5
●Φ5 Linkage ball D (M3x3.5) x 1
●Φ5 Long linkage ball (M3x4) x 1
This Product was added to our catalog on Thursday, 28. July 2016.
