Pictures of canopy shown are for illustration purpose only. Actual product may vary due to product would be dispatched randomly.
The T-REX 800E PRO is an 800 class flagship designed specifically for 3D flights. The CCPM direct connect servo design, coupled with FL rotor head assembly, results in fast, precise, and more direct control reaction. The frame material integration technology is utilized on the landing gears and vertical tail fin, creating a unique look not only making the T-REX 800E PRO stand out, but also resulting in an innovative design that encompasses structure rigidity along with beautiful aesthetics.
Nothing was spared in the electronics components of the kit: The mighty power of the 850MX(490KV/4535) motor paired with RCE-BL200A Brushless ESC speed controller for unparalleled power output; The new CNC machined aluminum cased DS830M brushless high voltage cyclic servos paired with DS835M rudder servo not only exhibited top of the line servo aesthetics, but also combine heat sink function and best performance in the market segment.
The T-REX 800E PRO can be described as the current top of the line flagship representing Align’s superior product line. Based on the pedigree of pure 3D flight, the newest design concept with absolute top of the line equipment, along with superior aesthetics and attractive lines, the T-REX 800E PRO will definitely elevate the adrenaline in your blood!
Focus Shots
Standard equipment
●Platinum HV 200A V4 Brushless ESC
●850MX Brushless Motor(490KV/4535)
●DS830M High Voltage Brushless Servo x 3
●DS835M High Voltage Brushless Servo
●Microbeast PLUS Flybarless system
Specification
● Length: 1490mm
● Height: 402mm
● Width: 204mm
● Main Blade Length: 780mm
● Main Rotor Diameter: 1740mm
● Tail Rotor Diameter: 301mm
● Motor Drive Gear:12T
● Main Drive Gear:112T
● Autorotation Tail Drive Gear: 104T
● Tail Drive Gear: 22T
● Drive Gear Ratio: 9.33:1:4.73
● Weight(With Motor): 4100g
Accessories
●T-REX 800E PRO Kits Set x 1
●780 Carbon Fiber Blades x 1 set
●115mm 3K Carbon Fiber Tail Blades x 1 set
●850MX Brushless Motor(490KV/4535) x 1
●DS835M High Voltage Brushless Servo x 1
●Platinum HV 200A V4 Brushless ESC x 1
●Microbeast PLUS Flybarless system x 1 set
●Receiver(6-channel or more)
●6S Li-Po 4500 ~ 5200mAh x 2
Microbeast Manual
