Focus Shots
Standard equipment
●T15 Main Blades x 1 Set
●15M Main Motor(1500KV/2405) x 1
●15MT Tail Motor(8000KV/1103) x 1
●T15 Digital Servo x 2
●T15T Digital Servo x 1
●T15 Tail Blades x 1
●Remote Extension x 1
●Li-Po Battery 2S 400mAh 50C x 1
A10 Specification
●Channel: 10-Channel
●Available Models: helicopter/airplane/multicopter
●Frequency range: 2.408 ~ 2.475 GHz
●Power: no higher than 20dBm
●System Mode: 2.4G system AFHDS 2A
●Suitable Voltage Range: 4.0 ~ 6.0V DC
●Receiving Distance: the open ground no interference <1000M
●Low Voltate Warning: Lower than 4.2V
●Weight: 487g (excluded battery)
●Size: 187x89.6x215mm
T-REX 150X Specification
● Length: 272mm
● Height: 85mm
● Main Blade Length: 120mm
● Main Rotor Diameter: 280mm
● Tail Rotor Diameter: 51mm
● Weight(Without Battery): 100g
Accessories
●T15 Kit set x 1
●A10 Radio Control System x 1
●T15 Main Blades x 1 set
●T15 Tail Blades x 1 set
●Li-Po Battery 2S 400mAh 50C(46.4x20.6x13.82mm) x 1
●T15 Carry Box-Black x 1
●1.3mm Hexagon screw driver(Blue/8.2g) x 1
●0.9mm Hexagon screw driver(Red/8g) x 1
●Feathering Shaft Wrench x 1
●T22 Thread Lock x 1
●Parts box x 1
T15G
