Focus Shots
Electric equipment
●850MX Brushless Motor(540KV/4535) x 1
RH70E23XW
Specification
●Length: 1356mm
●Height: 358mm
●Width: 187mm
●Main Blade Length: 650-730mm
●Main Rotor Diameter: 1542mm
●Tail Length: 105-115mm
●Tail Rotor Diameter: 279mm
●Motor Belt Pulley: 22T
●Belt Pulley: 50T
●Front Drive Main Shaft: 15T
●Main Drive Gear: 62T
●Autorotation Tail Drive Gear: 27T
●Tail Drive Gear: 23T
●Drive Gear Ratio: 9.38:1:4.83
●Max RPM(approx.): 2290RPM
●Frame Weight: Approx. 2.3kg
Accessories
●TB70 Kit Set x 1 set
●22T Motor Belt Pulley x 1
●700 Carbon Fiber Blades x 1 set
●105mm 3K Carbon Fiber Tail Blades x 1 set
●Receiver(6-channel or more)
●RCC-6CX Intelligent Balance Charger
●22.2V 6S 4000~5800mAh Li-Po Battery x 2
●Digital Pitch Gauge
●Multi-function Tester
●Flybarless System
●CCPM Brushless Servo x 3
●Rudder Brushless Servo x 1
●Brushless ESC x 1
Manual
