Come after T-REX 700X, Align now release T-REX 700L V2 as the high integrated upgrade model for you all.
T-REX 700L V2 utilizes EFL Flybarless Rotor Head System with extreme low CG design, effectively reduces resistance during 3D maneuvers, increased flight responsiveness and precision. In addition, the styling appearance harmony with red anodized and stainless color, bring out the high quality of helicopter.
Equipped with the new main gear, featuring reinforced overall gear structure and increased gear thickness, effectively improves gear’s anti torsion ability to prevent gear from deforming under extreme power, reducing gear wear and power loss.
The canopy for T-REX 700L V2 is manufactured with durable lightweight fiber material, and utilizing an engineered aerodynamic design. Also this extraordinary design includes a progressive lightweight landing skid to show its stylish and attractiveness.
The T-REX 700L V2 is equipped with the new 800MX(520KV/4530) motor which is highly efficient with superior power, excellent torque, low current draw, and is the most advanced motor approved by World RC Champions. The brand new RCE-BL130A brushless ESC supplies extreme power. The NEW DS820M/DS825M high voltage brushless servos are more efficient and outperform other servos in this class. To protect these servos the new high-end CNC aluminum case function as a heat sink allowing the servos to operate at a lower temperature.
Different from previous T-REX 700L generation, the T-REX 700L V2 will also be one of your favorites on your pocket list!
Focus Shots
Electric equipment
●RCE-BL130A Brushless ESC x 1
●800MX Brushless Motor(520KV/4530) x 1
●BL815H High Voltage Brushless Servo x 3
●BL855H High Voltage Brushless Servo x 1
●Microbeast PLUS Flybarless System x 1
RH70E30XW
Specification
●Length: 1350mm
●Height: 362mm
●Width: 195mm
●Main Blade Length: 700mm
●Main Rotor Diameter: 1582mm
●Tail Rotor Diameter: 281mm
●Motor Drive Gear:12T
●Main Drive Gear:112T
●Autorotation Tail Drive Gear: 102T
●Tail Drive Gear: 23T
●Drive Gear Ratio: 9.33:1:4.43
●Weight(With Battery): Approx. 5300g
Accessories
●T-REX 700L Kit Set x 1 set
●700 Carbon Fiber Blades x 1 set
●105 Carbon Fiber Tail Blades x 1 set
●Receiver(6-channel or more)
●6S Li-Po 4500 ~ 5200mAh x 2
●Digital Pitch Gauge
Microbeast
Manual
BeastX
