Focus Shots
Standard equipment
●T15 Main Blades x 1 set
●15M Main Motor(1500KV/2405) x 1
●15MT Tail Motor(8000KV/1103) x 1
●T15 Digital Servo x 2
●T15T Digital Servo x 1
●T15 Tail Blades x 1 set
●Remote Extension x 1
●Li-Po Battery 2S 400mAh 50C x 1
T15 Specification
● Length: 272mm
● Height: 85mm
● Main Blade Length: 120mm
● Main Rotor Diameter: 280mm
● Tail Rotor Diameter: 51mm
● Full Weight(Without Battery): about 100g
Accessories
●T15 Kit x 1
●Li-Po Battery 2S 400mAh 50C(46.4x20.6x13.82mm) x 1
●T15 Carry Box x 1
●1.3mm Hexagon screw driver(Blue/8.2g) x 1
●0.9mm Hexagon screw driver(Red/8g) x 1
●Feathering Shaft Wrench x 1
●T22 Thread Lock x 1
●Parts box x 1
Self-provided Equipment
●ALIGN T6 or Futaba S-FHSS 2.4G Transmitter. For the use of JR and Spektrum system, require JR DSM2/DMSS Transmitter and Satellite, Spektrum DSM2/DSMX 2.4GHz Transmitter and Satellite SPM9645.
●Battery Charger.
