Experienced in numerous of innovations, the brand new T-REX 500X is now ready to go. More attractive and creative design ideas are all in here, it absolutely would be your favorite T-REX 500X model ever.
Refresh and refine, T-REX 500X adapt with brand new FL rotor head system, utilizes an extremely low CG design which reduces resistance during 3D maneuvers while increasing flight responsiveness and precision. A progressive design adds a gloss silver and red anodizing appearance which continue our quality development based on our 700 class helicopter. The T-REX 500X main frame utilizes composite material integration technology on carbon side frame plates, including the addition of battery mounting side rails, and a top motor mount design. Innovative adjustable belt guide pulley, allows a convenient way to adjust the belt tension by releasing or tightening the screw. The screw is used to maintain optimal belt tension over time to keep the best. Also T-REX 500X landing skid is tilted 5 degrees forward to improve crashworthiness.
T-REX 500X utilizes 470mm main blades and 520MX(1600KV/3527) motor with 20% power upgrades than the original 1600KV/3225 motor. The latest new RCE-BL80X Brushless ESC support dual BEC output from 6 ~ 8.4V providing efficient and superior power. The NEW DS530M/DS535M digital servos are with extreme torque and speed response allow to support faster, more precise and accurate flight performance.
Equipped with all the top end electronic devices, T-REX 500X is as stable and powerful like the large scale helicopters. It is about to re-define the 500-class helicopters in your mind.
Focus Shots
Standard equipment
●RCE-BL80X Brushless ESC x 1
●520MX Brushless Motor(1600KV/3527) x 1
●DS530M Digital servo x 3
●DS535M Digital servo x 1
●Microbeast PLUS Flybarless System x 1 set
Specification
● Length: 935mm
● Height: 259mm
● Width: 151mm
● Main Blade Length: 470mm
● Main Rotor Diameter: 1054mm
● Tail Rotor Diameter: 219mm
● Motor Pinion Gear: 12T
● Main Drive Gear: 134T
● Main Drive Pulley: 80T
● Tail Drive Gear: 21T
● Drive Gear Ratio: 11.17:1:3.81
● Weight(w/o battery): approx. 1450g
Accessories
●T-REX 500X KIT Set x 1
●470 Carbon Fiber Blades x 1
●78 Tail Rotor Blade x 1
●Receiver(6-channel or more)
●6S Li-Po 2600 ~ 3300mAh (3300mAh suggestion)
●Digital Pitch Gauge
Microbeast PLUS
Manaul
